Starter drive disassembly?
BobShirleyAtlantaTx
First Name: Bob
Last Name: Shirley
Post by BobShirleyAtlantaTx » Sun Oct 13, 2019 1:03 pm
[attachment=1]image.jpg I’m trying to take a starter drive apart. Dose the bearing press off?
Jim Sims
First Name: Jim
Last Name: Sims
* REQUIRED* Type and Year of Model Ts owned: 17 touring 20 roadster 21coupe 25tudor 25 pickup 27 coupe
Re: Starter drive disassembly?
Post by Jim Sims » Sun Oct 13, 2019 1:20 pm
No not pressed on, it is threaded on then staked on from the inside into the two small holes.
BobShirleyAtlantaTx
First Name: Bob
Last Name: Shirley
Post by BobShirleyAtlantaTx » Sun Oct 13, 2019 1:29 pm
Thanks, Is it a right hand thread? Thanks again.
Post by DanTreace » Sun Oct 13, 2019 1:42 pm
Right hand thread. Here’s a how-to:
BobShirleyAtlantaTx
First Name: Bob
Last Name: Shirley
Post by BobShirleyAtlantaTx » Sun Oct 13, 2019 1:56 pm
. Thanks again
Post by Allan » Sun Oct 13, 2019 8:29 pm
It can be done with no special tools. I cut two round head nails just below the heads and these short bits go in the holes in the bearing. Then the bearing is held in the vice between aluminium soft jaws, the nails being there to stop it turning in the vice. A large pair of slide joint pliers engage on the gear to wind the assembly apart.
Hope this helps.
