Starter drive disassembly?
BobShirleyAtlantaTx
Topic author - Posts: 361
- First Name: Bob
- Last Name: Shirley
[attachment=1]image.jpg I’m trying to take a starter drive apart. Dose the bearing press off?
Jim Sims
- First Name: Jim
- Last Name: Sims
- * REQUIRED* Type and Year of Model Ts owned: 17 touring 20 roadster 21coupe 25tudor 25 pickup 27 coupe
Re: Starter drive disassembly?
No not pressed on, it is threaded on then staked on from the inside into the two small holes.
BobShirleyAtlantaTx
- First Name: Bob
Thanks, Is it a right hand thread? Thanks again.
Right hand thread. Here’s a how-to:
BobShirleyAtlantaTx
- First Name: Bob
. Thanks again
It can be done with no special tools. I cut two round head nails just below the heads and these short bits go in the holes in the bearing. Then the bearing is held in the vice between aluminium soft jaws, the nails being there to stop it turning in the vice. A large pair of slide joint pliers engage on the gear to wind the assembly apart.
Hope this helps.
Hope this helps.
