Getting Rattles Back On The Road
Re: Getting Rattles Back On The Road
If the carburetor is adjusted too rich, extra soot will get on the plugs and into the oil.
Mopar_man
Topic author - Posts: 1164
- First Name: Robert
- Last Name: Govoni
Took Rattles out for some practice. We're going on a small tour on Saturday. Just about 50 miles or so to a picnic with the Model T club. This small drive let us torque the head bolts after it was hot. We also took out the plugs and made sure they were clean. They looked good. I can also report that after sitting for months Rattles started right up and ran great!
First we oiled it up and did a safety check.
Then it was off to the drive. We were able to get it up to 39.5 MPH!
https://www.youtube.com/shorts/kpQ3UxUcio0
https://www.youtube.com/shorts/rqcq-2WTWN0
EdWhite
- First Name: Ed
- Last Name: White
- * REQUIRED* Type and Year of Model Ts owned: 1924 model t coupe
Awesome you have a new subscriber, we will follow along on your YouTube
Mopar_man
- Last Name: Govoni
Well My Mechanic came home from school and we got a few things done. Sorry I haven't posted in a while. Life sometimes has a way pf putting somethings on hold.
First I got the clock installed. I grew up in Waltham so it was kind of fitting to get one.
Mopar_man
- Last Name: Govoni
Then after taking the car out a few times I had to adjust the reverse band. This is the first adjustment I had to make. The reverse peddle went all the way to the floor and Didn't grab as well as I would like. I also found that the peddle was bent (normal for a 100 year old car) and was catching on the floor. So we cut the wood out a bit so it would clear. Someday we may bend the pedals back into shape. The floor isn't original so We didn't mind cutting it. Here are some shots and a video.
The video
https://youtube.com/shorts/e7-7T1Lw-zg
The video
Mopar_man
- Last Name: Govoni
Just got some pars in from Lang's. The first thing I'm going to tackle is the steering shaft bushing. I think I also may need a new Pitman arm and Key. It seems to be loose but I'll be able to check it better when I get it out. When I move the steering wheel very slightly I can see the shaft moving but not the pitman arm until the steering wheel moves a lot more.
The other thing I want to do is check the real axel. I used a borescope and I think I can see a bronze thrust washer on one side. I also received a lot of broken rear end parts and some Old style thrust washers that leads me to believe that they changed the washers out. I still want to take it apart and confirm everything was done right.
I'm not sure what these small disks are in the bag with the outside grease seals.
I also got these.
It says these are shims? This is the rest of the gasket kit.
I also got these.
The small metal plugs are for the late rux shifter shaft.
The red are the center axle thrust fiber washers.
Yes, Shims. They are for spacing the DS out a bit if needed for a little extra gear clearance.
Mopar_man
- Last Name: Govoni
Thanks John! I get it now. I knew about the fiber disks but I didn't know the Drive Shaft had that fine of an adjustment. I have a stock rear so I guess I won't need the small disks. Once I pull it apart I'll see what else I need.speedytinc wrote: ↑Mon Jan 12, 2026 8:06 pmThe small metal plugs are for the late rux shifter shaft.
Tparts
- First Name: Don
- Last Name: Lang
- * REQUIRED* Type and Year of Model Ts owned: Multiple years
The small metal plugs are used on the rear axle housing where the aluminum cap goes. There is a small hole that allows the sleeve dimple to seat into. They go into those holes, one on each side. When installed they will make a good surface for the aluminum cap (O-ring) to seal against.
Mopar_man
- Last Name: Govoni
Thanks so much Don. For the parts as well. I've got the rear axel book as well as the video.Tparts wrote: ↑Mon Jan 12, 2026 10:02 pmThe small metal plugs are used on the rear axle housing where the aluminum cap goes. There is a small hole that allows the sleeve dimple to seat into. They go into those holes, one on each side. When installed they will make a good surface for the aluminum cap (O-ring) to seal against.
